Previous in Forum: Study in the UK for 17th Edition   Next in Forum: Power System Stability
11 comments
Fault Level for Distribution Board
06/01/2010 7:07 AM
Dear Gents
Good Day
For distribution Board the required fault level 10 KA for 1 second & the vendor documents show that the fault level is 20 KA for 1 second ,,,, Is it ok to go to higher rate ?
Re: Fault Level
06/01/2010 7:12 AM
If the vendor documents are 20kA for 1 sec and the requirements are 10kA for 1 sec, then the board is compliant with the requirements.
Re: Fault Level
06/02/2010 4:18 AM
Thanks Alot
Re: Fault Level for Distribution Board
06/01/2010 1:21 PM
from the name i understand you are an engineer of six month course. Also understand that naturally you dont know about fault level.
06/02/2010 1:37 AM
Dear Ahmed
You wrote "For distribution board the REQUIRED fault level 10 kA for 1 sec.".
First - Fault level is NEVER A REQUIREMENT. It comes into picture due to capacity of source, connecting cables etc. Hence all components which see this fault level, have to be designed to withstand the given fault level. Anything higher is always acceptable.
Thanks and regards
Ashok Toshniwal, Bangalore, India.
PS - There are ladies too, on this forum.
06/02/2010 2:18 AM
Thanks Alot
That is what I need to know
06/02/2010 6:34 AM
If the upstream substation 66/11 KV has 25KA for 3 second withstand rating at 11 KV side, then is it required the down stream substation 11/.4KV also required 25KA for 3 secods??
06/02/2010 7:02 AM
Power rating & Percentage impedance of downstream transformer will decide the short circuit current & accordingly downstream short circuit withstanding capacity is decided. For example, if downstream transformer has 4% impedance then secondary short circuit current will be 25 times the name plate current & therefore short circuit withstand capacity should be decided accordingly. This is after neglecting impedance drop in transformer & assuming short circuit takes place directly at transformer terminals, otherwise resistance of connecting cables will add to the transformer impedance & therefore reduce the short circuit current.
Thanks and regards
PS - Pls. also introduce yourself.
10/17/2010 11:27 AM
If the consultant or buyer specifies 10kA for 1sec it becomes the requirement to satify site conditions
pnaban
06/04/2010 6:36 AM
Most Probably it is Dar or shakir or similar stupid engineering sorry for my language .
but it is really amazing on my last visit to middle east with my friend when a engrs from these companies asking us help and on the other day in meetings they throw the things on us ,Engineers are not engineers and very few you find good ones from INDIA PAKISTAN BANGLADESH but others flooded with fake degrees and make life miserable for others .
this is not joke learning is good but cheating is dishonesty
any one can disagree with me and critise me welcome all ,
but make sure you did a good googling before making any perception ...
cheers
Correct me if i am wrong i am learner
06/04/2010 11:54 AM
you are absolutely correct as mentioned in reply#2. 90% of cunsultancy and electromechanical companies in the middle east are filled with these type of intelligents.
06/04/2010 12:25 PM
Hi all
I agrees with you ikhanuk i have visited many times for consultancy in middle east .
My concern is when these fools dont know why they dont learn I have previlage to work with some of the pioneers in Europe in electrical engineers and it is really shameful for these people having greatest amount of money and output is zero . One of my collegue is indian he has worked in Jubail region for 12 years and often told us the inhuman behaviour and funny insulting laws for expatraits .Good Lord we dont have anything in like this in UK .They come to these forms ask question to screw people not to learn but
A little knowledge is always dangerous
I request my fellows please keep these fools away as Asians like Indian Pakistanis Bangladeshis are much better then this crap .
Thanks
Wil
Register to Reply 11 comments
Ahmed Fadl Elseed (2); Alanvaderi (1); Anonymous Poster (3); ashoktoshniwal (2); ikhanuk (1); pnaban (1); PWSlack (1)
