Previous in Forum: Outlet With Built In Surge Protector?   Next in Forum: Variable Speed Drive
Amount of Current
06/02/2010 2:05 AM
How much current will 630 mm Sq cable be capable to draw?
Regards,
Basole
Re: basole@alphakenya.com
06/02/2010 2:33 AM
→ British Standard 7671.
06/02/2010 4:12 AM
It depends on the ambient temperature, the type of insulation on it, the distance between it and adjacent conductors, and whether it is in open air, conduit, raceway, or buried in ground. BS 7671 in the U.K., the NEC in the U.S., and various local codes should have this information as it applies to your location.
06/02/2010 7:02 AM
and most important is type of conductor- copper or aluminum.
Good Answers: 804
Re: Amount of Current
06/02/2010 4:12 PM
Trick question actually. The real answer is... ZERO!
Conductors CARRY current, they do not "draw" current!
And to that end, conductors can "carry" any amount of current you try to allow them to. They cannot do it SAFELY beyond a certain limit, but the definition of "safely" varies by application and jurisdiction. In other words you can pump 100,000 amperes through a 1mm wire... for a fraction of a second.
Anonymous Poster (1); JRaef (1); PWSlack (1); Tornado (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
