I am playing with a couple of old R/C airplane engines that shot craps and was looking at the valve train set up. One is ported intake and exhaust, the other has a cam, push rods, rocker arms, springs and standard valves.
My Question is which one would produce more horsepower and/or torque in the MID RPM range? The ported engine ran faster at top end and both seemed to pull about the same at mid range. Both are .45 size. The ported engine is a two cycle with a glow plug, The cam rocker engine also uses a glow plug set up and uses two cycle fuel, But it has one intake valve and one exhaust valve. I assume (hate that word) it is a four cycle.
Does the glow plug HELP or HURT with extraction of exhaust gas with it being HOT during the entire 4 cycles? Both ran great until gravity raised it's head and they smacked NOSE first into the ground. For some reason they just won't run with a bent crank, darn the bad luck...
Yes, No, Well, How about a definite maybe and remember voluntary participation is mandatory.
