Previous in Forum: Biomass Requirement   Next in Forum: Time Required to Fill a Tank with Air
Eccentric Reducer Layout Development from Plate
06/03/2010 9:40 AM
can anyone explain how to develop the layout of eccentric reducer from plate
Good Answers: 61
Re: Eccentric Reducer Layout Development from Plate
06/03/2010 10:53 AM
There are three elements that are to be considered"
1. The diameter of the small end circle
2. The diameter of the large end circle
3. The length of the finished reducer
Convert the diameter of both circles to two straight lines the length of the individual circumferences.
Place these two lines on a large piece of paper the same distance apart equal to the length of the reducer.
Cut it out and roll it up to test. Correct as required.
If it is okay then use it as a pattern.
Do it once and do it right
12/14/2012 9:28 PM
i want know how to mark layput of exentric cone
12/14/2012 9:39 PM
Please consult a textbook on drafting, in the section usually titled "Developments and Intersections"; the process is difficult to describe with words alone.
06/19/2023 6:37 AM
So does Anonymous Poster #1.
06/03/2010 11:35 AM
The Franklin Pipefitter's Handbook might also be helpful.
dileeshretnakar (1); PennPiper (1); PWSlack (1); Tornado (2)
