Car will start for 2-3 seconds when key is on and 9 volts is measured at the injector plug.Car will then die out. And I get 1 -4 volts now measuring at the injector plugs. And of course it won't start again. I get no pulse at injector wire. I also ohmed out the injectors and they were at about 13 ohms.
I have been changing out parts from a running 2000 2.2 sunfire with this cavalier. The parts I have changed (trying to find this issue) is as follows:
Fuel pump, crank sensor, ignition module, map sensor, throttle sensor,ABS module and the air intake sensor.
I did get the car to run for about 2 hours and then same thing all over again. But it does seems to have gotten worse. I also hooked it up to a scanner and it read no OBD2 codes.
Any help would be greatly appreciated. I have been working on this*** blessed car for 3 weeks. And at wits end with it. THANK YOU!!!
