Previous in Forum: Doyle Rotary Engine P/V Graph   Next in Forum: Design Green House Automation - Give Your Feedback Here
DC Servo Motor and Generator
06/09/2010 9:11 PM
I'm looking for a DC servo motor that I can shut off and run in reverse and act as a generator.
kenn
Re: DC Servo Motor and Generator
06/10/2010 9:45 AM
If accurately controlling the position is not a concern, then any PMDC motor could help you; do a search in Google to find the one for your required voltage and current.
Yahlasit
06/10/2010 10:49 PM
Any brushless DC Servo motor does this, in fact, most controllers for them allow for dynamic breaking and can return the power to the supply. Many electric vehicles use this technology.
Good Answers: 119
06/10/2010 11:58 PM
Good Answers: 109
06/11/2010 2:32 AM
Hi,
brushless or not - both are good.
PM: the voltage is directly related by the K-faktor to speed (friction neglected).
K = voltage/2pi*rev/sec = torque (N*m)/current (amperes)
If you need an independent (from speed) possibility to change the voltage then you need a excitation-coil (instead of the permanent magnets).
A cars generator would be the cheapest choice.
RHABE
06/11/2010 9:06 AM
If it is brushless then the friction loss will be low.. so obviously efficiency will be more.
Power Plant Development
06/16/2010 9:42 AM
Portescap (usual disclaimer)?
07/13/2010 6:29 AM
HI,
Energy is a non renewable resource which is very useful.
[url=http://www.sterling-energy.com]Power Plant Developers[/url]
Register to Reply 7 comments
angelina (1); Anonymous Poster (1); baxterm (1); marchse (1); mjb1962853 (1); PWSlack (1); RHABE (1)
You might be interested in: DC Motors, Servo Valves, Servo Drives
