Folks, I have several 3 phase motors in my shop our in the barn. We have no 3 phase service out here in the country (Boone county, MO USA) I have a Rotophase to generate the 3 phase. It has been acting bad. I think the capacitors in it are going bad. I can start a 3 HP 3 Phase motor on the Rotophase but not the 4 HP motor in the lathe. The lathe motor has a lot of stuff to get turning on starting. After the 3HP motor is running, I can shut down the Rotophase and start and run the 4 HP motor just fine.
My questions are:
1. What in the world is happening? How does a three phase motor run on single phase? And how does it produce three phase to start other three phase motors?
2. If I operate the 4HP motor at it's rated power, with the 3HP motor doing its thing, will I over heat the 3 HP motor?
3. If I were to replace the Rotophase with a single phase motor running a three phase motor as a generator, why did I buy the Rotophase?
Thanks for your help.
Bob
