Previous in Forum: Meters to Metric Tons   Next in Forum: Study Strategy
13 comments
Tangents to a Circle
06/11/2010 1:16 PM
When tangents are drawn to a circle of radius R at three points, a triangle is formed. The sides of the triangle are 3R, 4R, 5R. Find sum of squares of sides
Re: tangents to a circle
06/11/2010 1:27 PM
You need to clarify this puzzle a little better with a diagram. Unless you think that 9R2 + 14R2 + 25R2 = 48R2 is tricky puzzle.
Re: Tangents to a Circle
06/11/2010 3:24 PM
Typographic correction: 9R2+16R2+25R2 = 50R2.
Reply Score 1 for Off Topic
06/11/2010 3:38 PM
Yes Sir, Thank You
Good Answers: 119
06/11/2010 8:15 PM
As 3,4,5 is a right triangle,
wouldn't that be
9*R2+16*R2 = 25*R2
sum of squares of the two sides is the square of the hypotenuse?
06/11/2010 8:42 PM
Maybe, that's why I asked for a clarification.
06/11/2010 9:33 PM
That is true, of course, but the wording of the OP seemed to ask for the sum of squares for all 3 sides.
For a bit more of a challenge, prove that the configuration is possible; i.e., that the circle is indeed tangent to the hypotenuse as well as the legs.
Good Answers: 74
06/12/2010 11:43 AM
Tornado,
How about this:
The radius, R of an inscribed circle would be Area/k where k is (a + b + c)/2, a, b and c being the length of each side.
In this case, k = (3 + 4 +5)R/2 = 6R
Area = 3R*4R/2 = 6R2
Radius = Area/k = R [QED]
Bruce
06/12/2010 4:10 PM
That's one way, but it relies on:
"The radius, R of an inscribed circle would be Area/k where k is (a + b + c)/2, a, b and c being the length of each side."
Which may be a bit obscure, and would itself require proof.
There are no doubt several ways to show this; mine was to use the triangle (0,0), (3,0), and (0,4) and show that the circle was tangent to the hypotenuse at (1.8, 1.6).
Good Answers: 74
06/12/2010 8:13 PM
Tornado, you are a hard taskmaster.
Inscribe a circle in any triangle with sides a, b and c. Assume the radius is r. Draw a line from the center of the circle to each vertex, dividing the triangle into three smaller triangles. The area of each smaller triangle is a*r/2, b*r/2 and c*r/2 and the area of the original triangle is r(a + b + c)/2.
In our case, the area is r(3R + 4R +5R)/2 = 6rR.
Since we have a right angle, the area is 3R*4R/2 = 6R2, so r = R.
Bruce
06/12/2010 8:47 PM
Quite right. Shortly after suggesting that (a+b+c)/2 might be "obscure," I realized it was simple, just as in your description. (Too many years since I studied geometry; I forget or don't see the most elegant solutions.) Nicely explained.
Good Answers: 101
06/12/2010 5:35 AM
This is just so pathetic. The OP doesn't know how to do even simple algebra like this!!!!
06/12/2010 8:13 AM
Uhhh... Wouldn't that just be 50R2? 9R2 + 16R2 + 25R2 = 50R2.
09/20/2019 11:14 AM
Yes, it geometrically must = 50R2
ba/ael (2); DVader1000 (1); mjb1962853 (1); MR. Guest (1); redfred (3); Tornado (4); Usbport (1)
