Hello CR4's
I have a Hammond power solutions transformer. (480 delta primary volts, 208Y/120 secondary volts)
It is being used as a step up transformer.
PN:NMK030KB http://www.hammondsales.com/pdf/section10.pdf (See page 16 of the PDF document SCD 21 for the wiring diagram)
Is it possible to connect the windings of the 480 VAC side to make it a star connection? (480Y/277)? For instance connect tab 3 of each winding for neutral and have H1, H2 and H3 be the lines.
The transformer would be rated for a max of 36 amps in the secondary (480 vAC side) We would not place more than 14 amps.
Thanks
