Previous in Forum: cable manufacturing   Next in Forum: Transformer Laminations Power/Hydraulic Cutting Tool
8 comments
P.N Rating For Valves
06/16/2010 1:57 AM
Can someone tell me what should be the PN rating of a valve having cold working pressure of 14kg/cm2?
Pathfinder Tags: PN ratng of valves
Re: P.N rating for valves
06/16/2010 3:59 AM
14 kg/cm2 ≈ 198 psi (lb/in2). From this I would guess that any PN rating of 200 or greater would be satisfactory. This is only a guess, because I don't work within the PN designation system.
Re: P.N Rating For Valves
06/17/2010 1:56 AM
Refer to din standards.
Generally, it should be only PN 10
06/19/2010 2:21 AM
Sir,
Thankyou for your reply.Also i would like to know if Cast Iron to IS 210Gr FG220 would be suitable for valve having cold working pressure of 14kg/cm2.
Thanks & Regards
Pareen Shah
06/17/2010 7:07 AM
Hi Shah,
PN 10,according to DIN standards is covering the mentioned condition.This is equivalent to ASME pressure rating of class 150.
Sayed Sarhan
06/17/2010 7:13 AM
If I am correct, at room temperature, permitted working pressure according to ASME class 150 is 19 bar. This is much more than working pressure of 14 Kg/cm^2 of original post
06/17/2010 8:00 AM
Hi gsuhas,
ASME Class 150 is covering a range of pressures and temperatures,if you refer to ASME/ANSI B16.34-1988,ratings for group 1.1 materials(A105 and others),table 2-1.1A,standard class,you will find that working pressure of class 150 is covering the following range:
working pressure 285 psig at -20 to 100 deg F and up to 20 psig at 1000 deg F.
The subject pressure (assuming it is at room temperature)is laying within this range.
Sayed Sarhan
06/18/2010 2:16 AM
• The attached figure demonstrates the DN & PN and Class of flange (Link:
ASME_Flanges_Class_PN & NPS ).
•To find the Class (Rating) or PN of a flange, valve, or flanged connection, you have to define a 3 parameters:
- Design Pressure
- Design Temperature
- Material
• Then go to ASME B16.5 for NPS 1/2 up to NPS 24 (DN 15 up to DN 600) or ASME B16.47 for NPS 26 up to NPS 60 (DN 650 up to DN 1500).
06/21/2010 4:26 AM
pressure rating for 14kg/cm2 is 150class, because for 150 class, seat test pressure is 22kg/cm2.
Register to Reply 8 comments
Abdel Halim Galala (1); Anonymous Poster (1); gsuhas (2); sayed sarhan (2); shah_pareen (1); Tornado (1)
