Previous in Forum: New Motor Not Running   Next in Forum: Master Key For RS Logix 5 Damaged
Earth Resistance Values
06/16/2010 6:13 AM
What are the values of earth resistance of following installation 1) 33kv and below class sub stations and transmission lines 2) 66kv class sub stations and transmission lines 3)110kv class sub stations and transmission lines 4)220kv and above class sub stations and transmission lines
Re: earth resistnce values
06/16/2010 8:39 AM
How much is the marks in total that you are going to give the answer??/
Reply Score 1 for Off Topic
Good Answers: 42
06/16/2010 8:43 AM
Please refer IEEE 80
06/16/2010 10:33 AM
If I had that I wouldnt ask you here!!.... Have you read that??,,,
Reply Score 2 for Off Topic
Good Answers: 42
06/19/2010 2:11 PM
Dear friend If I do not have a copy I would not have adviced you. For a good engineer possession of such documents are essential.Read clause 14.1 of IEEE 80 . Sorry I am not supposed to reproduce here but I qute the contents below for your information.
"A good grounding system provides a low resistance to remote earth in order to minimize the GPR. For most transmission and other large substations, the ground resistance is usually about 1 Ω or less. In smaller distribution substations, the usually acceptable range is from 1 Ω to 5 Ω, depending on the local conditions."
Note .
Please be more polite in making coments that is the decency in a forem like this.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Earth Resistance Values
06/16/2010 11:38 AM
It was 5ohms when we measured before installing 15mva tfr for a 110/11kv substation here.
Anonymous Poster (2); hithuanand (1); V.I.Abraham (2)
