Previous in Forum: Diesel Level Measurement   Next in Forum: Hook-ups
Powerwizard 1.0 password
06/16/2010 1:41 PM
Sallam Alaikum,
Currently want to change the response of a generator control panel named Powerwizard 1.0.
Password is required to do this.
If the Will of the Almighty guides any experience to this path,let a say be heard.
Allah's will be done
Re: Powerwizard 1.0 password
06/16/2010 2:01 PM
If you are the registered owner of the machine, the manufacturer of the controller should be able to help. If not, Divine intervention may be the only way.
06/16/2010 2:15 PM
Profound advice, lynlynch. Delicately stated as well.
06/16/2010 4:13 PM
Thanks Doorman,
Restraint isn't one of my strong points, either.
06/16/2010 2:29 PM
Thank you
06/20/2010 3:24 PM
PowerWizard is a product of F.G. Wilson, an Irish generator builder, it is not a registered product, password is only to protect generator from changing critical parameters,
password usually is setup by the commissioning engineer, not by the manufacturer,
however there is a master password, you can contact your FGWILSON local dealer with the serial number of your engine. gen set , they will provide you a master password, at your own responsibility.
In Nigeria i can suggest this FGW dealer:
www.jubailibros.com
you will find their phone number and email adress, they will help you, but not for free
Good luck
dont say it, write it
Safety - Hazmat - New Member Technical Fields - Project Managers & Project Engineers - New Member
08/11/2010 9:27 AM
Not so sure about this but I thought that all the parameters for the generator are set on the change - over switch and not on the control panel. Which change-over switch do you have (MTI, ATI, CTI)? For the ATI and CTI you need a password but for MTI no password required.
"It doesn`t make sense to hire smart people and then tell them what to do, hire smart people so they can tell you what to do."--- Steve jobs.
Register to Reply 6 comments
Doorman (1); Le_Noble (1); loveHim (1); luyombya (1); lyn (2)
