Previous in Forum: Powerwizard 1.0 password   Next in Forum: ISA5.1 & KKS Tagging
Hook-ups
06/17/2010 2:38 AM
How to start to made Instrument hookups.
Re: Hook-ups
06/17/2010 3:34 AM
Same way as you connect most things...one at a time ans test as you proceed.
(By the way your question is so vague as to be almost meaningless)
Re: Hook-ups
06/17/2010 3:38 AM
In most cases, you should start be reading the instrument manufacturer's instructions. They will usually tell you what size of wire and type of shielding may be needed. The local electrical code may govern any power wiring, and any control wiring above a certain voltage. Low-voltage sensor wiring depends mostly on shielding requirements.
Re: Hook-ups
06/17/2010 7:56 AM
It's also good to know what the test is measuring and at least one method how this is done. You will find this from a good education.
Re: Hook-ups
06/18/2010 5:32 AM
In all cases, follow the original equipment manufacturers' instructions.
PWSlack (1); redfred (1); Tornado (1); user-deleted-1105 (1)
