Previous in Forum: Lightening(thunder) arrest   Next in Forum: LINE VTG
Rotation of Hydro-Generator and Turbine
06/18/2010 5:33 AM
Is it true that for rotation of hydro-generator and turbine, we have to first know the layout of Penstock and all before deciding on direction of rotation? Please do enlighten me.
Re: Rotation of Hydro-Generator and Turbine
06/18/2010 9:10 AM
You can't use a generator built in the southern hemisphere in the northern hemisphere and vice versa. If you do, they will suck all the electricity out of the wires and explode.
06/18/2010 12:10 PM
I can only imagine what it must be like to live in lynlynch world!
06/21/2010 2:03 PM
It's a laugh a minute. I'm a Gemini, what can I say? I'm as serious as a heart attack about some things, and then again..........................
06/19/2010 2:15 AM
It can be true for a Pelton Wheel but for other types of water turbines direction of motion is governed by spiral casing and the wicket gates, for the Kaplin turbine the water flow is axial here also the layout of penstock is not a consideration.
Knowledge sharing is a WIN-WIN situation
06/19/2010 2:37 AM
Six of one and half a dozen of the other. If you pick the turbine rotation first, then you have to design the penstocks to feed in the matching direction. If you design the penstocks first, then you have to select the turbine rotation to match the infeed direction of the penstocks. Tomayto, tomahto. (Classically known as mutatis mutandis.)
06/20/2010 1:28 AM
Thanks everyone for both the sarcastic and not so sarcastic reply. I will try to squeeze the best. info. from it.
09/25/2023 10:04 AM
The question is unanswerable, because the forum knows nothing about the capability of <...we..>.
Register to Reply 7 comments
Doorman (1); lyn (2); Merle (1); mountk2 (1); PWSlack (1); Tornado (1)
