Previous in Forum: Vibration Spectrum Analysis   Next in Forum: Train induction motor
18 comments
Mercedes C240 Problems
06/18/2010 10:41 AM
I have a 2001 Mercedes C240 and recently got a ESP visit workshop malfunction, the check engine light came on, the car vibrated and slowed down. I had to shut it off and restart. I was told I needed the YAW sensor. I replaced sensor and now check engine lights is on again. It says that cylinder #6 misfired. They checked the coil, the spark plug,wires & fuel injector and it was OK. It drives great until it reaches 4000 RPM then the check engine light comes on and it slows and vibrates. What else could be causing this. The YAW sensor cost me $550.00 w/o labor and I have limited funds to spend. Can someone help me please!
Re: Mercedes C240 Problems
06/18/2010 11:57 AM
You have replaced the YAW sensor. Have you replaced the PITCH and ROLL sensors?
We do not have ESP, ya know.
(Sorry, lanney. Not picking on you, just having a little fun with you. You'll get used to it!)
06/18/2010 1:13 PM
No, I am going to try to change the MAF sensor. Another C240 owner had a similar problems (car shudders @ 3200 RPM) Will try a "Junk Yard."
06/18/2010 1:34 PM
There are at least two gentlemen that are more familiar with Mercedes that are regulars at this website. If they can't come up with something that can help you we'll give it a shot, but there is no substitute for good experience.
h
Good Answers: 60
06/18/2010 1:38 PM
Good Answers: 60
06/18/2010 1:42 PM
i take it its a fuel injected engine ?
are there any error codes stored on the ecu ?
reason i ask its possible that no 6 injector is failing.
so when revs reach a certain point the cylinder is missing the ECU picks this up and turns no 6 off hence the misfire, then car goes into limp home mode to protect itself.
06/18/2010 8:20 PM
YAW sensor is part of the stability control system and MAF is fuel management.
I can't help you, but this sounds like two different problems.
I am not one of the two gentlemen to whom Guest referred.
06/18/2010 9:10 PM
Sorry , but you were one of the two to whom I was referring. You know what this means now I have to give it a shot unless Peter's suggestions direct him to the possible solution. A shot is about 1 oz. isn't it?
h
06/18/2010 11:24 PM
Thanks.
Good Answers: 97
06/19/2010 12:04 AM
Good Answers: 60
06/19/2010 1:23 AM
Good Answers: 97
06/19/2010 1:45 AM
So you did...okie—dokie
Good Answers: 123
06/21/2010 10:26 AM
If the misfire is from cyl #6, and only at above 4,000, I would save some money, and do some substitutions first. I think the easiest thing to do is move the coil to another cylinder. Drive above the 4,000 threshold, and see if the light comes back on. If so read the code. If it is still #6, the coil was not the cause. Next try the spark plug. Same test. Next the plug wire. By using components from different cylinders for testing, and noting where they came from, you can do all the tests at once. That will avoid paying four times for the reading of the codes if you do not have access to a reader. ( Coil from #1, plug from #2, wire from #3, and injector from #4.) Although the coil fires two cylinders (I think) it could still have a breakdown problem that only affects one cylinder. My personal guess is the injector. I think other components would recover as soon as the car is below the 4g threshold. But an injector might not. Only you will have that answer. Good luck.
Bob
06/21/2010 10:45 AM
My mechanic switched everything from the number #3 cylinder to the #6 and the same thing happens. He also says that it wasn't the fuel injector. I might have to take it straight to the dealer if we do not come up with another solution soon. We changed the fuel filter and the car is driving better than before, except for the 4000 RPM problem. I am totally frustrated.
Good Answers: 60
06/21/2010 11:17 AM
this may sound silly but is there any way you can check to see if there is a blockage in the inlet port going to no 6 cylinder ?
firing order
http://www.justanswer.com/questions/2flyv-what-is-the-firing-order-of-the-2003-mercedes-c240-and-what
Is your engine a V or inline ?
injector faults
http://www.carsuk.net/mercedes-blueefficiency-om651-injector-problems/
Good Answers: 123
06/21/2010 11:41 AM
Once the car exibits the 4g problem, how do you correct it again?
Bob
Good Answers: 123
06/21/2010 10:27 AM
By the way, welcome to the insanity.
Bob
06/21/2010 11:43 AM
Thank U.. at least I know that I am not alone.
Register to Reply 18 comments
Anonymous Poster (2); bob c (3); bwire (2); Doorman (1); lanney (3); lyn (2); peterg7lyq (5)
