Previous in Forum: Sudden Drop of Pump Discharge Pressure   Next in Forum: High Vacuum Systems
Testing of Valves
06/20/2010 8:35 AM
Can some one help me to find out a procedure to determine whether a valve can withstand vaccum.also let me know the suitable set up for the same.
Re: Testing of valves
06/20/2010 8:51 AM
Is the valve rated for vacuum duty? It's as simple as that.
Good Answers: 141
Re: Testing of Valves
06/20/2010 9:04 PM
You have vacuum? Which one - meaning how much vacuum? Manufacturers also specify also how much of a vacuum a valve is vacuum sustaining. You can test this also when you have vacuum and a vacuum meter and test it (even on both sides). Connect your valve to a vacuum tester (type automobile pump) and see how the needle of the meter acts over time. If you are talking about high vacuum, get yourself some better measuring stuff. If your valve is cheap and it works, lets us know the make and model. We might be interested too.
Plenty of room here
06/21/2010 5:13 AM
The manufacturer's data sheet for each valve says it all.
06/21/2010 8:34 AM
Close one end using O-ring and and other end of valve on vacuum tester apply vacumm and stop vacuum tester and monitor pressure drop with time
Compare that with flat glass sheet vacuum stability. We do this as routine and will work for you also
Masyood
Good Answers: 27
06/21/2010 9:02 AM
Vacuum is the absence of air or atmospheric pressure. I believe maximum negative pressure possible or achievable is about 760 mmHg. Noticeable differences will only depend on the rate or how fast this negative pressure is created. Any positive pressure air /liquid valve rated to exceed or sustain an equivalent positive pressure should work as well in negative pressure applications.
vsar
dvmdsc (1); lyn (1); Masyood (1); PWSlack (1); vsar (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
