Previous in Forum: Can We Use 120v AC Adater In 220v AC Socket ?   Next in Forum: GFCI 50Hz
Electrical Problem - Metal Oxide Varistor
06/21/2010 10:47 PM
Dear All, I need to share MOV problem that related with electrical problem. The problem related with digital MOV. Please, if anyone can give me idea to share about MOV problem. My case : 1. The digital circuit at first become the main problem. But, in the end the digital circuit is ok. I ran out off idea, how to solve it. I need an idea to solve ( at least I know the problem), step by step the we must consider to solve it.
Pathfinder Tags: MOV
India - Member - New Member
Good Answers: 164
Re: electrical problem MOV
06/21/2010 10:59 PM
Do you mean a Metal Oxide Varistor? Are you sure it has been properly selected for the application, and meets the voltage and energy criteria? Are you aware that MOVs degrade over time and may need to be replaced?
It would help if you can explain the problem a little more clearly.
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
06/22/2010 12:27 AM
True, we would need to know much more details. Assume that we don't know anything about your circuit/project.
CraziestOzzy
Re: Electrical Problem - Metal Oxide Varistor
06/22/2010 2:53 PM
Register to Reply 3 comments
CraziestOzzy (1); kvsridhar (1); PWSlack (1)
You might be interested in: Step Recovery Diodes, Digital Audio Systems
