Have you checked the data sheets and/or manual as the information should be in there?
Have you talked with the supplier?
Alternatively, please provide more detailed information on your application and what a GFCI is (and the model number and brand of the one in question).
RCD = residual current device (?). GFCI = ground fault circuit interrupter. Different words for essentially the same thing. The RCD's rating of 30ma (suited to an industrial breaker) is not as sensitive as residential GFCIs rated at 6ma, but the idea is identical.
Besides the question of if the device will work... there may also be a legal issue with using this device.
In Canada, you could only use this device "legally" if the device was dual rated for use with a supply source of 50 and 60hz. If it does not carry certification for use on a 60hz source, you would not be allowed to use it.
This may or not be an issue for you. Only referring to your local rules and regulations will answer this question.
As this is a life safety device, you may want to have your ducks in a pretty little straight line.
