Previous in Forum: Solar Panel Spacing   Next in Forum: Stator Ring Connection Question
10 comments
Hinged Beam Reaction Forces
06/22/2010 11:48 AM
Is there any general formula for reactions on hinges of beam length L supported by hinges at both end and subjected to force P at centre.
Re: hinged beam reaction forces
06/22/2010 12:24 PM
Yes. Consult any textbook on Statics.
06/22/2010 12:49 PM
statics books assume one hinge and one roller support to reduce the number of unknowns
can we assume the same in the design of pinned connections?
06/22/2010 12:53 PM
Only if the beam is not sagging either under its own weight or that of an applied load.
06/22/2010 1:06 PM
since the load is at center and the beam is symmetrical in shape why the forces on both hinges is not considered equal?
06/22/2010 1:11 PM
It can't be seen from here; without a sketch it is anyone's guess.
Re: Hinged Beam Reaction Forces
06/22/2010 3:08 PM
Under "normal" assumptions, if W is the weight of a symmetrical beam, and an additional force P is imposed at the center, the reaction at each end will be F = (W+P)/2.
If the beam is restrained between solidly fixed ends, then thermal expansion/contraction, or sagging, may result in considerably larger forces. In that case, we need to know the "hinge" details.
06/22/2010 4:10 PM
F=(W+P)/2 is this the resultant force?
06/22/2010 4:24 PM
06/23/2010 12:08 AM
The Force must be with me today--I say something and it is repeated. I don't suppose this quotable gem will get into Bartlett's, though.
06/23/2010 2:06 AM
well, gentlemen what I believed that either the owner's question is student try to understand his homework or someone did not have a glue on mechanical engineering basic. If I am correct than I would suggest that he or she should go through the static book before come back with more questions.
Anonymous Poster (5); PWSlack (3); Tornado (2)
