Previous in Forum: Diesel Engine Using Too Much Oil   Next in Forum: HHO geneators??
8 comments
1998 XJ8L Jaguar
06/23/2010 11:38 AM
On the gearshift, one side is automatic, and moving the shift to the left it goes into a different ratio or something that is like race mode.
What does that mean?
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: 1998 XJ8L Jaguar
06/23/2010 12:21 PM
What does the owners manual say?
Give me enough duct tape and I can fix anything!
Good Answers: 60
06/23/2010 12:44 PM
Could you specify which model you are talking about ?
Off the top of my head, one would be a normal gear change the changes being set to occur with economy in mind.
in race i would assume the gear change would occur later ie allowing the engine to rev up higher before each change.
http://en.wikipedia.org/wiki/Automatic_transmission
http://auto.howstuffworks.com/sequential-gearbox.htm/printable
http://www.carmagazine.co.uk/News/Search-Results/Industry-News/Tomorrows-world-dual-clutch-gearbox/
http://www.jaguar.com/gb/en/#/about_jaguar/jaguarreviews/xfreviews/reviews
http://www.carpages.co.uk/jaguar/jaguar-x-type-part-3-13-10-07.asp
06/23/2010 12:49 PM
It means that you should leave it in automatic if you don't know what moving it really does.
Good Answers: 60
06/23/2010 12:58 PM
Good Answer if in doubt leave it in D.
06/24/2010 7:55 AM
Good Answers: 60
06/24/2010 8:33 AM
The description for the sports mode matchs my description.
Good Answers: 123
06/24/2010 8:55 AM
If the lever is left in the automatic side of the shifter, the transmission will select the correct forward gear ratio for the conditions it sees. When brought to the left side, the shifter will allow you to select whatever forward gear ratio you desire.
Be careful, if you select the wrong gear, you will ruin your engine, your transmission, possibly your rear differential, possibly your tires, possibly ruin your fuel mileage and add additional pollutants to the air. You may also increase your likelihood of looking like a fool if you try to use it in front of someone that actually does know how to use it.
Bob
06/24/2010 11:02 AM
Great answer, thanks all.
I'll tell my wife don't go there.
Shawdog2
Register to Reply 8 comments
Anonymous Poster (1); bob c (1); farmatt (1); lyn (1); peterg7lyq (3); shawdog2 (1)
You might be interested in: Over-the-Side Heaters, Fiberscopes, Solid State Relays
