Previous in Forum: LPG Hose Type   Next in Forum: Free body diagram of a massless part
AHU Mixing Chamber Box
06/23/2010 4:33 PM
for AHU mixing chamber box, what material for damper should be selected for better performance and long life, can we go for GI, or we should for aluminium power coated, also please suggest for prefilter.
for condensate drain TRAY which is better aluminium or SS304
Re: AHU Mixing Chamber Box
06/24/2010 12:44 AM
AHU?
06/24/2010 2:10 AM
One of the less known acronyms, this stands for "air handling unit." This type of unit involves more than just an evaporator coil. There may be provisions for mixing outside and recirculated air, reheating coils for humidity control, filters, exhaust air, positive/negative pressure rooms, etc. In other words, more treatment is provided than cooling alone.
06/24/2010 2:17 AM
If the controlled space is at high humidity, GI may rust, so aluminum is likely to be better. If there are corrosive vapors or mists present, SS304 or even SS316 is likely to be better still. Special conditions may dictate yet another choice of materials. This all depends on the specific situation. Fiberglass or plastic ductwork and other components might also be desirable.
