Previous in Forum: multiple choice question answer instrumentation   Next in Forum: Control Through GPRS
DP Transmitter
06/26/2010 12:30 PM
I am doing loop checking of dp transmitter. Where calibarted range is :0 to 100 mbar
and flow is minimum:3.1 metercube/hr max : 3.8 metercube/hr
but when i am neumarically calculating, something is going wrong
Flow= k(meter constant)x√ ΔP , our meter constant is 1, process fluid is water
then on max flow
flow= 1x√100/1000 bar
= 0.3166
but it should me 3.8 metercube/hr
Can you tell me , where i am doing mistake, plz
Re: DP Transmitter
06/27/2010 10:10 AM
Dear Guest,
Volumetric flow when passing through the orifice area of the flowmeter produces d/p head that is proportional to the square of the velocity of the fluid at that point. Only after the square root is extracted is the signal from the d/p transmitter proportional to volumetric flow. If you account for fluid and meter constants properly you will have a signal that is linear with flow. The square root extraction causes large errors when the flow reduces by a factor of three or more from full rated flow. You have not mentioned the d/D ratio or the size of your orifice, segmental plate, flow tube, or pitot device in your calculation. I only mention the most common flow devices, but you must account for what creates the differential pressure.
Luther M
There are old pilots and there are bold pilots, but there are no old bold pilots.
Re: DP Transmitter
07/02/2010 8:41 PM
We also encountered inaccurate reading while we did field calibration on a flow x'mtr. the reading in the x'mtr is diffrent from the calculated values. later it was corrected when we extracted the squaroot.
You might be interested in: Gas Flow Meters, Radio Transmitter ICs, Flow Meters
