Previous in Forum: Motor   Next in Forum: Current Carrying Capacity of Solid Bus Bar
Electrical Engineering - Calculate kwh/year
06/26/2010 1:04 PM
Dear friends,
If my Kw=2300@0.70 PF what will be my kwh/year,if my cost is 8$/unit
If i use capacitor bank and improve my PF to0.95 what will be my Kw and savings with the same cost 8$/unit.kindly show the formula /calculation.
With thanks and regards.
suresh.
Re: electrical engineering
06/26/2010 1:11 PM
You'll need to provide more information about usage.
What is "8$/unit"?
Re: Electrical Engineering - Calculate kwh/year
06/27/2010 2:10 PM
You will pay the same thing-meter reads KWATT not KVA.
PF value does not make any difference.
06/28/2010 4:38 AM
2300kw x 365 days x 24 hours = 20,148,000 kwh.
If the unit cost is US$8, then 20,148,000 x 8 = $161,184,000....
Somehow I doubt this. For one thing, the more likely unit cost is 8¢. If so, your bill would be $1,611,840. Not only that, but you might not be using the 2300 kw all of the time.
You need to find out whether and/or how much your utility charges for low PF. Then you can calculate how much you can save by improving the PF. The data so far are inconclusive.
Register to Reply 3 comments
lyn (1); Tornado (1); zacky (1)
