Previous in Forum: Solar Desalination Tank Glass & Steel Thickness   Next in Forum: Exhaust Fan Sizing
06/26/2010 10:53 PM
bottob is 500*500 mm
height is 10 mm side and 40 mm another side
the tank cover will be glass
this used in solar desalination
tank have 1 inch pipe supply and 4 inch outlet to condenser
pressure inside tank is 10 kpa (0.1 bar absolute)
i want to know thickness of steel and thickness of glass
This discussion was "closed" on 06/27/2010 2:13 PM. No new comments are allowed.
Message from admins:
This was posted as a reply to another thread. Please submit your replies to the original thread: http://cr4.globalspec.com/thread/56430
Good Answers: 101
Re: reply
06/27/2010 12:03 AM
You're doing this to provide drinking water for a Third World nation, aren't you? If that is the case, it would be better to use metal drums instead of rectangular structures. They have less sharp angles to accumulate stress, so it will be a lot safer. Also, the kind of special purpose high strength glass is very costly even in First World nations; you might not even be able to get it locally, so you may have to pay a fortune to have it imported.
Re: reply
06/27/2010 4:25 AM
no way its restriction for me these dimensions and configurations
if you know stress equations that i can use to calculate thickness or to calculate deflection please send me quickly
Re: reply
06/27/2010 12:23 AM
If you support the glass at some intermediate points with standoffs from the sheet metal opposite, you can use economically thin materials. However, the pipe sizes seem way out of proportion to the likely throughput of water.
(Hmm...I wonder if any backwoods Kentucky guys have already mastered this technology.)
Re: reply
06/27/2010 4:31 AM
no option to make supports inside tank
just tank just glass
Re: reply
06/27/2010 4:39 AM
help me
Re: reply
06/27/2010 4:47 AM
To the last three questions: Why, Why, and Why?
Re: reply
06/27/2010 4:52 AM
its my master and i follow system and supervisors
Register to Reply 7 comments
Anonymous Poster (2); DVader1000 (1); Tornado (2); wedaallam (2)
