Previous in Forum: Continuous Recording   Next in Forum: Solar Desalination Tank Glass & Steel Thickness
10 comments
06/26/2010 7:42 PM
how to calculate thickness of rectangular tank with internal vacuum and external atmospheric pressure?
Good Answers: 141
Re: need help
06/26/2010 10:45 PM
Need to know the volume and the dimensions of the tank, and if the tank has reinforcements in it, and what material you want to use. And how deep your vacuum is. A rectangular tank is a difficult one. Sphere or cylinder are more appropriate.
Plenty of room here
Re: need help
06/26/2010 10:51 PM
bottob is 500*500 mm
height is 10 mm side and 40 mm another side
the tank cover will be glass
this used in solar desalination
tank have 1 inch pipe supply and 4 inch outlet to condenser
pressure inside tank is 10 kpa (0.1 bar absolute)
Good Answers: 141
Re: need help
06/27/2010 12:09 AM
YOUR ANSWER IS NOT OFF TOPIC: bottom is 500*500 mm height is 10 mm side and 40 mm another side the tank cover will be glass this used in solar desalination tank have 1 inch pipe supply and 4 inch outlet to condenser pressure inside tank is 10 kpa (0.1 bar absolute) Where are the resp. inlet and outlet? Is this a kind of looking glass in a water suction circuit?
Plenty of room here
Re: need help
06/27/2010 4:29 AM
no way its restriction for me these dimensions and configurations
if you know stress equations that i can use to calculate thickness or to calculate deflection please send me quickly
pipe inlet and outlet in the bottom face
the condenser outlet in the long side of 40mm the cover of tank is the glass and sustain the same vacuum pressure
Good Answers: 141
Re: need help
06/27/2010 2:59 PM
The thickness of your glass is not the main issue, rather than how you apply it to the frame and how it is treated. You will need to provide a good frame and elastic seal and bed to lay your glass in or on. You will need glass that is tempered and according your box design the thickness will be 4 mm minimal = rather critical, 5 or 6 mm for that 500 X 500 frame. The glass has to be cut and hardened in this rank. Grind down the sharp edges on cuts and corners before hardening. (hardening is here the process to manufacture safety glass) If meant for mass production I should consider a casted box - epoxy coated.
Plenty of room here
Re: need help
06/28/2010 1:51 AM
thank you very much but how you calculate thickness of 4 mm as critical and what you recomended thickness of the glass?
Good Answers: 141
Re: need help
07/03/2010 2:15 AM
Ha, 4 mm glass, made with sand from Mol (BE) is able to withstand the same pressure over that surface. I do not know where you live and how good the glass is there. That is why I recommend 6 mm. Approx. 2.2 to 2.5 tons 1kg/cm2. Ask your supplier. Uneven gasket or seat construction may change these figures drastically. Still wonder how you get to THAT vacuum?
Plenty of room here
Re: Solar Desalination Tank Glass & Steel Thickness
06/27/2010 2:35 PM
See also the companion thread on this topic, which apparently was an accidental duplication of this thread, and was closed.
06/28/2010 3:59 AM
If the tank is not to be built to a vessel code, go back to first principles:
  • Take theoretical slices through the tank and carry out a force balance on the slice plane. Repeat ad nauseam.
Rectangular tanks are less able to withstand pressure differences than tanks based upon curves; these withstand pressure differences better while using rather less structural material. That is why cylindrical vessels with dished ends and spherical vessels find better favour.
06/28/2010 4:43 AM
I think the OP is under the thumb of pointy-haired bosses who have restricted him from adopting good information.
Anonymous Poster (2); dvmdsc (4); PWSlack (1); Tornado (2); wedaallam (1)
