Previous in Forum: Basic Wind Speed   Next in Forum: Fire Suppression Systems in Single Family Dwellings
How to make 8000 PSI Concrete
06/28/2010 12:33 AM
plz tell me the ratio that how to make 8000PSI concrete
Good Answers: 179
Re: How to make 8000 PSI Concrete
06/28/2010 10:16 AM
If you are not a civil engineer don't bother trying to design 8,000 psi concrete because you'll fail at it miserably. Leave that up to the concrete supplier and their tech support, who are the pros.
If you are a "degreed" Civil Engineer and went through engineering college with the requisite course, then I strongly suggest that you revisit your past materials lab studies and work, plus review the "Strength of Materials" course that you should have taken (and stayed awake in).
Have a great day!
06/29/2010 1:32 AM
This is a deep, dark secret--revealed only to the strongest shamans, or those who possess the correct licenses. Neither of those two groups will ever tell, so you must fall back on your own research.
09/16/2017 11:44 PM
First of all: I will tell you how to do get 8000 PSI concrete.
Having said that, I am saddened to see some people in the industry act like jerks, just because an engineer told them how to do YET they make the most money out of it. Greediness truly is the Achilles' heel of this great nation. It's sad seeing people act secretive about 8K psi concrete, when I been studying on making 100K psi concrete (yes 100,000 psi) though my research has already been done, I'm merely bettering the process and attempting to go pass the 106,000 psi barrier.
Anyways, 8K psi concrete is not entirely "tricky" but there are two ways you can make it DEPENDING on why you need it: Personal OR commercial.
If you need it for some personal reason (up to 9K psi but could be a bit less), the ratio is as follows:
Materials
Quantities
(per yd3)
Quantities
(per m3)
Cement, Type I736 lb437 kg
Fly Ash, Class F130 lb77 kg
Fine Aggregate1321 lb784 kg
Coarse Aggregate1600 lb949 kg
Water263 lb156 kg
High-Range Water-
Reducing Admixture
43 fl oz1.66 L
Air-Entraining
Admixture
4.5 fl oz175 mL
Water-Cementitious Materials Ratio0.300.30
NOTE: I did told you I'm working with 100,000 psi concrete right? Although it doesn't apply to my field, try to keep the coarse aggregate as small as possible, between 1-2 inches in diameter. Although it doesn't apply too much in "normal concrete", smaller coarse aggregate will be much better than the crap you get in construction companies. If you're buying, insist in going to their facilities in person.
If you need it for commercial purposes, I may not be able to help you. I think the psi needed to do high rise skyscrapers is around 15K psi to 20K psi... it could be less, but my research started there. We can talk more about this if you're interested, but I find that area boring.
Que Dios te vendiga.
amandabankai (1); CaptMoosie (1); Tornado (1)
