Previous in Forum: What If We, "Mankind", Could Fly Just Like a Bird?   Next in Forum: Maintaining Different Pressure in Different Rooms
Modulation of a Fan
06/28/2010 4:40 AM
our gas collection and treatment system is equiped with a centrifugal fan. when the system resistance is reduced, the flow rate reduces instead of increasing. we want the flow rate to be constant independent of the system load.
also, when the system load decreases, the quantity of available gas decreases
what do i do to modulate the fan inorder to have constant flow rate at all times
Re: modulation of a fan
06/28/2010 4:57 AM
Actually measure the flow rate by pitot tube or something. Interface this signal with a VFD to drive the fan, together with some programming, to maintain a (nearly) constant flow.
Good Answers: 27
06/28/2010 5:51 AM
When the system resistance is reduced a centrifugal fan will supply more flow not less (up to a "stonewall" point where it will not increase further). A reduction in flow rate with a reduction in system resistance is against the laws of physics. You have some other phenomenon coming into play such as belt slip or something else.
I have no special talent. I am only passionately curious. Albert E
