Previous in Forum: Thoriated Tungston Rod   Next in Forum: Insulated Bearings
12 comments
Temperature
06/29/2010 1:24 PM
What is the effect if 3 different ducted indoor units were installed in one location above ceiling without any partition to isolate them from each other?
Good Answers: 141
Re: Temperature
06/29/2010 1:51 PM
What effect? What Units? You can add all effects together. Input - Output - Noise - Weight - Work - Expenses. For you to chose.
Plenty of room here
Re: Temperature
06/30/2010 12:12 AM
I mean the effect from sensing the return temperature.Each unit has its own set point because of different locations it served.But their returna air temperature is mixed inside the above false ceiling.Will this affect my thermostat sensing?
Re: Temperature
06/29/2010 4:35 PM
It will have the immediate effect of baffling a good engineer from a lack of definition. But now that the baffles are installed the operation becomes clearly obvious and requires no further discussion.
Re: Temperature
06/30/2010 12:20 AM
It all depends upon how your duct distribution system is designed. IF each unit has separate supply and return duct system I do not anticipate any mixing of air. As three units work at the same location nose level may be a problem . For that roper acoustic treatment can be carried out. You may have look the condensate drain also. If it is not properly installed it will spoil the ceiling.
Re: Temperature
06/30/2010 9:48 AM
mr.swamy.what if the return air for each indoor unit is not ducted, there will be mixing of air right?Then it follows that a mixed temperature will create, therefore there will be effect on the sensing of thermostat for each different area being conditioned?
Re: Temperature
06/30/2010 10:56 PM
Yes
the 3 thermostats will sense the same temperature as the 3 units are sucking the same air...
result: your 3 units will start and stop at the same time if you have same settings,
and , as they are serving different location, temperature regulation will not be accurate
I suggest to set the a little difference in thermostat setting not to have a big rush current on your electrical grid
for the noise, I will not elaborate it as it is not your concern
Greetings
dont say it, write it
Re: Temperature
06/30/2010 12:29 AM
I think we need a more complete description of what ducting is shared versus separated. And maybe an assessment of how much heat is rejected into the above-ceiling space. For this we need to know the details of each of the three units.
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Re: Temperature
06/30/2010 1:30 AM
1. NOSIE, NOISE, NOISE, NOISE Last year, one smart engineer in my office decided to put (4) 5-ton units close to each other and I can tell you, the combination of the noise factors is not a linear..
It is better to fail in originality than to succeed in imitation.
Re: Temperature
06/30/2010 2:44 AM
True enough; it would be about √n, which is not linear.
Re: Temperature
06/30/2010 4:43 AM
I sincerely suggest you read up on octave bands before you put your self out in the open like this...
Good Answers: 141
Re: Temperature
06/30/2010 3:11 AM
It is linear on a logarithmic scale. Double the noise is 3dBA plus.
Plenty of room here
Re: Temperature
07/01/2010 5:53 PM
position (and calibration) of the T-stats in each area is critical for temp. control.
H T H cheers
Register to Reply 12 comments
Anonymous Poster (2); dvmdsc (2); Economist (2); Le_Noble (1); mrswamy (1); munch (1); redfred (1); Tornado (2)
