Previous in Forum: Water Pumps   Next in Forum: Emergency Lowering Load For Offshore Crane
Stress Relieve A Pipe
06/29/2010 11:25 PM
If your going to stress relieve a pipe weld with the wall thickness of 37mm and you have a shoe (that is basically a saddle pad with a shoe welded to it) with the thickness of 13mm that is to be seal welded,
Does this 13mm weld need to be stress relived? Or can it be attached after PWHT? It's not pressure containing because it has a weep hole drilled in it.
Pathfinder Tags: Stress Relieving
Good Answers: 38
Re: Stress Relieve A Pipe
06/30/2010 11:10 AM
Suggest that you purchase and review the code of record.
ASME B31.1 and B31.3 contain rules about the types and thicknesses of joints that require stress relief.
What are the materials of construction and what is the thickness of the largest part being joined...?
Is this new construction or a repair being performed by a contractor who has never done this type of work before ?
Is there a qualified weld proceedure for this joint ?
Engineering Fields - Piping Design Engineering - New Member
07/01/2010 3:41 PM
What's the material of pie and the saddle pad? Also mention the welding filler wire / electrode you would be using for welding? If the material is of carbon steel, there is no need for PWHT as per ASME B31.3.
Regards,
Ashfaq Anwer
http://thepetrostreet.com
07/01/2010 5:55 PM
All the materials are P1 material and wire is ER70S-G.
I want to install the shoe afterwards. The spools will be cooked in a furnace.
Do you know what section is referenced?
Thanks
07/01/2010 11:43 PM
See ASME B31.3 section 331.1.3 "governing thickness" para (1) 'not required for P-No. 1 materials when weld throat thickness is 16 mm (5⁄8 in.) or less, regardless of base metal thickness'.
You may go for stress relieveing in the furnace and then after welding the saddle, perform the hydrostatic test.
Regards,
Ashfaq Anwer
Good Answers: 38
07/02/2010 3:36 PM
Stres relief of components must always follow the code of construction as well as common sense.
Sometimes the original design is changed to a configuration that will avoid stress relief through use of thiner sections.
ashfaqanwer (2); efharbe (1); MJCronin (2)
