Previous in Forum: Stress Relieve A Pipe   Next in Forum: New Product Idea-Night Vision Contact Lenses
Emergency Lowering Load For Offshore Crane
06/29/2010 11:51 PM
Hi All,
I have just received a request from offshore well head platform asking for engineering a solution to lower load in case lost of power supply. This is a high level safety issue as crane also use to carry people. Is there anyone experience in this, please help.
Thanks,
Thieu
Pathfinder Tags: crane
Re: Emergency lowering load for offshore crane
06/30/2010 12:42 AM
Please give more specifics.
If this is a hydraulic crane or platform, a bleed-off needle valve will do the job.
If it is a cable drum, some sort of release combined with a brake could also do this, but the details would be more tricky.
Mountain climbers would just rappel.
Good Answers: 16
06/30/2010 4:17 AM
First step is to provide specific crane details. 1
If this crane is currently in service on a rig or platform I am surprised to think it doesn't already have an emergency lowering scheme on it as most do.
Do your homework and I do mean all of it... Check all regulatory societies associated with your location and specific application.
Check API standards, BV, Lloyds, ABS, the specific drilling companies QSMS/ISM, etc....
What ever you do must be built around there standards and limitations, not ours. Once you know what you can and can-not do, offer this information along with more specifics on the crane in question and it will be time for a solution to your problem
06/30/2010 4:19 AM
In the UK it is not lawful to lower people on a crane or in a lift without using power to do it, and were it to be otherwise the Engineer/Surveyor for the company providing indemnity insurance would not cover any liability for using the equipment.
Consider hooking the crane into the standby generator system.
Re: Emergency Lowering Load For Offshore Crane
06/30/2010 11:54 PM
Thank to all,
I did check and found that the crane has already the emergency procedure for load lower . Yes, I have to do my home works and build the modifications around code and standards as your advices.
Register to Reply 4 comments
PWSlack (1); thieumv (1); Tim in Mexico (1); Tornado (1)
