Previous in Forum: Does slower fan consume less energy?   Next in Forum: Neutral Grounding Resistor
Pre-Commissioning and Commissioning
07/01/2010 3:31 AM
Hello sir's.
whats the difference between pre-commissioning and commissiong, and whats the job responsibilities and activities involved.
thanks
Re: pre- commissioning and commissioning
07/01/2010 4:11 AM
pre- commissioning :- all the testing and checks which shall be done before the operation or recieve power to the equipment like cable continuity test , insulation resistance test, hi-pot test ,leak test ,instrument calibration , primary injection of CT,protection relay check ,.....
commissioning :- all the activities and testing which shall be done during start-up of the machine or the equipment including the maneuver and energize (power recieve to the equipment) like interlock test, Electric parameter mesuring , vibration check , nose measure,synchronization,flow check....
07/01/2010 5:41 AM
Terminology is synonimous to; cold commissioning and hot commissioning.
Knowledge sharing is a WIN-WIN situation
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
08/03/2012 10:21 AM
I would be glad of references for this proposition and about hot and cold comissioning generally.
07/01/2010 5:47 AM
Before commissioning and during commissioning.
Some activities need to be carried out before commissioning for example complete equipment testing viz. HV, Primary injection. secondary injection etc will be carried out in pre-commissioning stage. Important tests like trip test, mechanical operation etc will be repeated during commissioning stage.
Good Answers: 170
07/01/2010 7:39 AM
"COMMISSIONING" is putting into service.
And, pre-commissioning is - making the system and/or equipments ready for putting into service.
Re: Pre-Commissioning and Commissioning
04/05/2013 12:37 PM
Dear friend,
PRE-COMMISSIONING refers to the individual equipment trial/testing while there can be several equipments, each with different in-put-output parametres and make ready for commercial production, and make a smooth starting of commercial production and reach the rated capacity.
If this exercise is not conducted, then during commercial production i.e commissioning, the plant has to be stopped - for example, leakages, electrical fault, vaccuum problem etc.
COMMISSIONING refers to OVER-ALL/COMBINED TRIAL and then start Production with raw materials input, and get the end product.
POST-COMMISSIONING - will refer to activities/rectifications to be carried out by taking a planned shut-down of the plant,for different type of problems, in different equipments and fine tune the equipments, and re-start the plant to achieve the targets.
DHAYANANDHAN.S
Anonymous Poster (1); dhayanandhan (1); electricalexpert65 (1); Geoffrey36 (1); kanmano (1); mountk2 (1)
