Previous in Forum: Another Welding Gas Question   Next in Forum: Soda Blasters
Engine KW VS Generator KW Output
07/06/2010 12:49 AM
Hello,
Can someone please help me explain why is engine KW output different from that of a generator KW output?
I am new to this field...came across a 10 KW gas genset, engine output = 13.4 KW and genset is 11 KW..how does this work?
Good Answers: 145
Re: Engine kw vs generator kw output
07/06/2010 1:27 AM
Basically, it takes power to generate the power.
There are "losses" to overcome in the process of creating the output current, the generator will cause a substantial drag on the motor, when it is fully loaded, at its fully rated electrical power output. So the motor needs to be able to overcome that drag with some capacity to spare.
Also the Motor needs to operate at the specified engine speed to provide the appropriate output frequency. This may be at a point in the torque /power curve of the motor that is less than its rated full speed power output rating.
I'm sure some of the other Guru's can elaborate with numbers and calculations to prove the point definitively.
07/06/2010 1:45 AM
Thankyou, thats exactly what I wanted to know...appreciate your help
07/06/2010 4:25 AM
If the engine kW output were the same as or lower than the generator kW output, then the engine would either stall or not be able to keep up with the electrical load before the generator were fully loaded.
07/06/2010 8:24 AM
Yea..now I understand...I am new to this field and trying to market the product so need to understand how stuff works....
cool joke by the way!
Re: Engine KW VS Generator KW Output
07/09/2010 7:59 PM
The engine also has to have some reserve so that the genset can start motors that momentarily require more than the rated kw. I'm not sure if the same factor is used universally, but it might be something like 1.3.
Anonymous Poster (1); PWSlack (1); sdspower (1); Tobugrynbak (1); Tornado (1)
