Previous in Forum: CR4 Tool Bar Missing In Google Chrome Browser   Next in Forum: Automation by Cell Phone
Pin Out DB25 MODBUS
07/06/2010 12:02 PM
Dear Fellows,
Do you have the pin out DB25 connector for using in MODBUS protocol.
Re: Pin Out DB25 MODBUS
07/07/2010 3:19 AM
CR4 ADMIN: Deleted Post #1
This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
mutual benefits!
07/07/2010 12:05 PM
Hello ATC
A shameless attempt to drive traffic to your site. Not for long...
07/07/2010 11:32 AM
Try this link http://www.modbus.org/docs/Modbus_over_serial_line_V1.pdf
A man wants to know everything about everything, a woman wants to know everything about everybody
07/07/2010 9:08 PM
CR4 ADMIN: Deleted Post #4
mutual benefits!
07/08/2010 1:31 PM
Modbus is a protocol, it has no standardized wiring, because the wiring depends on the hardware comm link used to transport the protocol data.
A DB25 connector is commonly used as a serial RS-232 or a Centronics parallel printer. The shape of the connector does not define the hardware connected to it.
Assuming that it's an RS-232 port, a conventional standard pinout is available here
http://www.zytrax.com/tech/layer_1/cables/tech_rs232.htm#db25
07/08/2010 1:42 PM
Thanks again Carl, the link it seems to be what I am looking for. I appreciated your help.
NOTES:
  • Leave any pins not specified above unconnected.
  • In balanced mode signals with the same name are the paired set, for example, pins 2 and 14 are both named BA and form the Transmit Data pair. Each signal of the pair is either a high (A+) or low (B-)
  • When used with RS-485 in half-duplex, multi-dropped environments a simple three signal arrangements is frequently used - one pin is used as a GND and RX/TX is alternately switched onto a balanced pair of wires which can be either the BA (TX) or BB (RX) pair.
Register to Reply 6 comments
ATC (2); Carl_E (1); Doorman (1); FLUKE744 (1); MOURADIG (1)
