Previous in Forum: Instrument and Electrical Earth Bars   Next in Forum: VFD Motor
Deatection of Neutral Missing
07/07/2010 2:12 AM
Please let us know how to detect the neutral wire missing in a 3 phase balanced and unbalanced load.
Re: Deatection of Neutral missing
07/07/2010 2:43 AM
Switch off some single phase loads like lighting from one of the phases, use a v meter between neutral and ground.
Knowledge sharing is a WIN-WIN situation
Re: Deatection of Neutral Missing
07/08/2010 1:32 AM
The Question should be very specific as what is exactly required, because neutral missing in a balanced or unbalanced load means, the load is an industrial equipment.
Since neutral missing in a domestic usage is no meaning as if it is missing no single phase equipment works.
07/08/2010 2:48 PM
GA for a good common sense (and accurate!) answer......
07/08/2010 3:14 AM
Connect a single-phase load between one of the phases and neutral. If the load does not operate, then neutral is disconnected between the supply and the load point.
"Simples! ξ"
07/08/2010 5:42 AM
Missing neutral? From Where? You can't find the neutral wire or there is none connected ?
really, your question is unanswerable unless by someone with the same kind of environment logic!!?
amarnath.sn (1); Andy Germany (1); LAA_Lucke (1); mountk2 (1); PWSlack (1)
