Previous in Forum: Fuel Cells and Heat Pipes   Next in Forum: Who can deliver Steel Cylinders 50 litre@200bar
Cement Silos Steel Fabricated
02/26/2007 1:46 AM
Pl note that i want design of steel fabricated nut bolted cement silos not
welded capacity 2000m tons each total 5 nos, along with air arration system
to avoid cement blokage,spacificatins,maximum height 14 meters clear space
required 4 meters from the ground level to the discharge cone of cement silo
for the filling of cement bulkers by gravity. I also required design of
concreat foundation for these cement silos.
Re: Cement Silos Steel Fabricated
02/27/2007 5:07 AM
Which budget do you have to buy the plans or make people do this work for you ?
02/27/2007 6:45 AM
Please reply these Q's
  1. Where is the location?
  2. Do you have in-house fabrication?
  3. Do you have 2 cranes 2 M-Ton lifting&holding at top of 25m ?If else, what?
  4. What width Carbon Steel plates 6,8,10,12,16 mm thick xL= ?can you get at location?
  5. What Yield Point- say Kg/mm-sq material readily available of above plates?
  6. Are you more concerned for Time-of Completion oir Total Cost?
  7. What is the location's Soil Condition-Clay,Sandy, rocky
  8. What is the water Table depth?
  9. Will you pay for 1 trip all-found+$2000 fees?
03/12/2007 11:12 PM
Good Day Mate,
Here's The Info You Need
http://ferrocement.com/tankBook/indici.en.html
Happy Tank Building !
Cheers
Bondjamesbond@rock.com
03/13/2007 5:31 AM
But Mate-he wants in bolted Steelfab--
Not Welded Steel,
Not RCC
Not Ferrocement:
welded
Cheers to you too for the great Ferrocement web Site!
mikemahant@hotmail.com
03/14/2007 8:39 PM
Yes, Quite
Your Right Of Course
My Mistake
You might be interested in: Cement Boards, Utility Meters, Cement Tiles
