Previous in Forum: Anybody Know Where I Could Get a Miniature Cyclical Transmission?   Next in Forum: FRP Piping
Oncology Treatment--HVAC
07/08/2010 6:28 PM
Dear colleagues, I need your help regarding a room 10'x10' in area, it will have a special chamber to treat oncologic substances, the model of the chamber is a NUAIRE NU-440-400, Im concern about the conditions of the air conditioned to the room, do you know of any literature or recommendations for the air treatment of this systems??
appreciate your help
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Re: Oncology Treatment--HVAC
07/09/2010 6:28 PM
The NU-440-400 specs say that it can use up to 1440 watts (12 x 120), which equates to about 4900 Btu/h. Each person in the 10' x 10' space will add about 400 Btu/h, and each electrical item will add 3.41 Btu/h per watt. If the exterior of the 10' x 10' space is warmer than the space itself, there will also be heat conduction through the envelope and infiltration through open doors/windows.
All of this should be added up to give the total Btu/h for the air conditioning system. I'm just guessing on this, but most likely this will be within the capacity of a simple through-wall AC unit.
I have not addressed any special clean room or filtration requirements for the 10' x 10' space. The Nuaire unit has its own filtration system, so MAYBE the outer room will not need anything further. But be sure check that matter, too.
07/10/2010 12:07 AM
you will find required information at the website shown you can down load the report a word document
http://www.his.org.uk/_db/_documents/OTIC-final.doc
crm
ex power user
Good Answers: 27
07/16/2010 4:53 PM
In addition, an air exchange rate must be incorporated to ensure certain degree of isolation for the room. I suppose this to be a positive type of isolation from the rest of the hallway with an an ante room in between.
vsar
Peru - Member - New Member Engineering Fields - Biomedical Engineering - New Member Popular Science - Genetics - New Member Fans of Old Computers - Commodore 64 - New Member
07/10/2010 12:52 AM
Clean Room, Bone marrow Transplant, Before Proyect
We must understand the things like are and not to try that they are as we want.
Register to Reply 4 comments
Anonymous Poster (1); Grage Tesla (1); Tornado (1); vsar (1)
