Previous in Forum: Chemical Composition Of Miild Steel Sch 40 pipe   Next in Forum: Condensate Extraction Pumps (CEP)
Attach Worm and Worm Wheel in Roller
07/09/2010 3:06 AM
Hi,
i have two roller in parallel . so how to connect the worm and worm wheel with diagram&example . i want to reply immediately . thank you
regards
kuthupulla
Re: attach worm and worm wheel in roller
07/09/2010 5:33 AM
how do you want the 2 rollers to rotate wrt to each other? Same direction or Opposite?
are they driven by the same worm? i.e. by the same prime mover and at the same speed?
rahulpshinde
07/09/2010 9:21 AM
rotate to opposite direction and driven by the same worm
Re: Attach Worm and Worm Wheel in Roller
07/09/2010 4:04 PM
The worm (or shaft) needs to pass between the worm wheels on each roller. This may be an unusual custom application.
07/11/2010 7:54 AM
exactly.
I have seen some applications in steel rolling mills having this kinda of arrangement.
the worm gearing CD would be half of the Roller CD.
rahulpshinde
kuthupulla (1); rahulpshinde (2); Tornado (1)
You might be interested in: Worms and Worm Gears, Roller Screws
