Are you a valve manufacturer? If you are (no doubt), why should anyone give you a free answer? The reason you are in business is to develop your own products. So, DEVELOP YOUR OWN PRODUCTS!!!!!!!!!
For LPG which contains Butane, natural rubber should not be used, as it will be attacked and perish.
You will need a special plastic compound as butane is extremely 'hard' on plastics, I think Viton is the material of choice but please check with a pneumatic supplier of valves for use with butane and propane.
