In generator winding the conductors has much needed forced cooling by Water and/or Hydrogen. The current flow in Generator bus bar in bus duct is also same as in Generator winding but the not that much of cooling is required. In case of 500 MW / 0.8 pf generator the full load current is in the range of 16 Kilo Amp, even though the bus duct doesn't has any forced cooling.
( it is arguable that, inside the casing the other losses causes much heat and winding heat is to be extracted by external medium)
In bus duct the surrounding is heat free but a sealed one hence there will not be no any heat removal. Needs clarification.
Thanks always.
