Previous in Forum: Car Mileage, Should I Be Worried?   Next in Forum: Sealing Screw Threads
22 comments
My Car Won't Shift Out Of Drive
07/12/2010 8:56 AM
i was driving to work this morning and everything was normal.. i pulled into my spot and when i went to shift my car (2000 3 speed automatic chevrolet cavalier) into park the shifter moved really easily, and caught me off gaurd.. when i went to get out of the car i realized that it was still in drive; even though i had moved the shifter to park. i then quickly realized that moving the shifter did not change the gear the car was in. i couldnt get it in neutral, park, lower gear, reverse, anything.. it was stuck. the car was registering that the shifter was in park however because i wasnt able to take the key out while the shifter knob was "in drive" but when i pulled the e-brake and moved the shifter knob to park (even though the car was still in drive) it let me turn the car off so I could go inside.
im thinking a cable came loose from underneath the shifter assembly, but its been years since i worked on this car and wanted to know if anyone had any other ideas or at least something temporary so i can get the car home...
thanks
Re: my car wont shift out of drive
07/12/2010 9:03 AM
If you are the adventurous type, turn the key to the on position so you can steer, push it back out of the space, start it up (If you can) and drive it home.
If it were mine, I'd call a tow truck.
Good Answers: 58
07/12/2010 9:09 AM
I think you are right on - something in the shift linkage came loose. Being a 2000, I have assumed that it is not under warranty.
By virtue of the park/neutral safety interlock switch, you will not be able to start it in drive.
The safest suggestion I have is to have it towed to a repair shop.
You could jack it up, go under and shift the tranny into park so you could start it but then you would have to go back under neath to shift it into drive while it is running. ****I DO NOT RECOMMEND DOING THIS - IT IS DANGEROUS****
Best bet IMHO, have it towed and repaired.
07/12/2010 9:50 AM
yeah i wont be climbing under anything while it is running or anything like that.. im going to pull it apart and see if its *hopefully* something quick... if not i reall ydont have any other choice but to tow it
07/12/2010 10:43 AM
well it came disconnected from the engine bay.. the shift cable eyelet on the end dry rotted and came off the transaxle manual lever... does anyone know if i need to replace the whole cable or can i just replace the end that broke?
Good Answers: 60
Re: My Car Won't Shift Out Of Drive
07/12/2010 10:44 AM
Sorry to have to say this, But you seem to have the least reliable car in the world.
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=cavalier&order=asc
there have have been hundreds of cavalier faults, but if i can find out a cure for yours i will.
Dont buy another one
07/13/2010 7:31 AM
Yep. My son had one up to a few months ago. Nothing but trouble. He had a similar problem with his shifter. For a time, he was parking on a slope so he'd be able to back up, then it would go into drive. We rehabbed our old BMW for him, now he doesn't have to worry about it anymore. Best move ever. Get rid of it.
Ted Kennedy's car has killed more people than my gun.
Good Answers: 60
07/12/2010 10:45 AM
Good Answers: 60
07/12/2010 10:47 AM
  1. Ask a Mechanic OnlineChevrolet.JustAnswer.com 15 Auto Mechanics Are Online! Ask a Question, Get an Answer ASAP.
Search Results
  1. WikiAnswers - Why is my automatic transmission stuck in drive and ... Cars and Vehicles question: Why is my automatic transmission stuck in drive and the shifter just moves freely on a 1997 Cavalier? Please help us answer this ...
    wiki.answers.com/.../Why_is_my_automatic_transmission_stuck_in_drive_and_the_shifter_just_moves_freely_on_a_1997_Cavalier
  2. Shifter cable cavalier Problems my car went from being stuck in drive to stuck in nuetral when i shift it feels loose. ... Describe your 97 chevy cavalier automatic stuck 97 chevy cavalier ...
    www.fixya.com/tags/shifter_cable_cavalier
  3. 1997 CHEVROLET CAVALIER OWNERS MANUAL | PRINTER AND SERVICE MANUAL 9 Jul 2010 ... Download Free 1997 Chevrolet Cavalier Owners Manual.pdf This 1997 Chevrolet ... Player ~ AM-FM Stereo with Cassette Tape Player and Automatic Tone Contro ... If You're Stuck: In Sand, Mud, Ice or Snow; Service and Appearance Care ... Suspension and Front Drive Axle Boot and Seal Inspection ~ Exhaust ...
    printer1.blogspot.com/.../1997-chevrolet-cavalier-owners-manual.html
  4. Chevrolet Cavalier Reviews Chevrolet Cavalier Reviews - CarReview.com is the leading resource of quality ... Transmission options are; a 3-speed automatic, a 4-speed automatic, ... Absolutely no problems, and it's fun to drive. I just wish it wasn't winter so .... I am just a working man and I thought that I was stuck into this car for life. ...
    www.carreview.com
  5. 2004 Chevrolet Cavalier speedometer stopped working ... So now i have to drive my car without a speedometer until i can find a better .... Cavalier. Automatic transmission; 31000 miles. Speedometer stuck on ...
    www.carcomplaints.com/Chevrolet/Cavalier/.../speedometer_stopped_working.shtml
  6. YouTube - 1997 Chevrolet Cavalier 2.2L OHV 0-60 Mine only has 1,2 drive because mine has the 3 speed automatic. ... tell me why the chevy I bought is so slow and sucks so bad I should of stuck with ford ...
    www.youtube.com/watch?v=d6dr1CWawAw
1
6
7
8
9
10
Next
07/12/2010 11:00 AM
yeah i know cavaliers arent the best cars in the world.. i drive one :)
i just need it to keep chuggin till i can save up some cash.. i presume i can't just buy one end of the linkage cable... i need to get the whole damn thing ?
Good Answers: 58
07/12/2010 11:06 AM
Elf,
Unfortunately yes, you will most likely have to buy the whole assembly. If you are going to keep the car for a while, don't buy from a auto junk/salvage yard. If you do, the one you buy may be on it's last leg.
You don't say what part of the globe you are located but if you are in the US and have a Pepboys near you, they are very decent with their repair prices.
Good Luck!
07/12/2010 11:11 AM
yeah the reason this part failed is because its old and rotted, i can only imagine that a yard would have pieces in the same or worse condition
does anyone know how the linkage actually connects to the gear selector? The post that the eyelet connects to has a round ball on the end of it, im assuming it just snaps on there? Maybe there is some sort of solution that could last to allow me to get it home or to a shop.. i really dont want to have it towed...
Good Answers: 60
07/12/2010 11:36 AM
07/12/2010 12:02 PM
thanks for the links
Good Answers: 60
07/12/2010 1:40 PM
No Probs hope they help
could you perhaps temp secure to cable end to the g/box with couple of hose/jubilie clips
07/12/2010 5:05 PM
i was thinking zipties, but a hose clamp might work better... ill see what i can do - short of making a shift cable that goes out my window :)
Good Answers: 60
07/12/2010 5:14 PM
zip ties wont hold tried that some years ago, if the cable is still there and goes to the gear selector hose clamp types will be stronger, any flexing should be absorbed by the cable, just remember to shift slowly.
or you could go tot he scrap yard cut of the last part of the cable with the connector or o ring part, and attach the cut of part using the clamps
09/26/2010 7:56 AM
Had the same problem yesterday. The cable popped off because of dry rot. You can reach under the intake pop cable back onto ball stud. Then drive away because you are pulling the cable. When you goto to park, you are "pushing" the cable this is why it pops off. I zip tied for now with a heavy duty tie band, . Instead of changing the cable I am pulling the bracket off. Cut off the ball stud and put 10.9 bolt in its place. The eyelet goes over the bolt and a nut with thread locker will keep it place. This is more of a fix than replacing the cable and waiting for dry rot again.
07/13/2010 9:50 AM
You should be able to access and manually move the shifter with the hood up. (No crawling undercar ). Get a friend to help out.
07/13/2010 9:51 AM
Best to park up against something quite substantial that moves out of the way when time to resume driving. Tow truck is good too.
12/27/2013 3:34 PM
Elf, I drive a 99 cavalier and am having the same problem. But I can't seem to find the part that you are talking about. Where under the hood is it located??
Register to Reply 22 comments
Anonymous Poster (2); cinnastix3 (1); dirty elf (6); Igotmine (1); KJK/USA (2); lyn (1); peterg7lyq (8); sensorscontrols (1)
