Hi everyone how do you seal the screw thread with the adhesive by hand or machine?If by hand can you kindly inform us how you do it,if the machine please also inform us the way.Thanks
Hi, i am an electrical engineer so i should not be really answering this, but what the heck, i use Loctite for screw sealing. Quite often manually, but here is an image of an automatic line that i worked on in Germany (not Loctite, simple paint to seal the screw in the adjusted position)
When you say sealing a screw thread did you mean to stop it from vibrating loose in service. Or was it meant to mean that you have a pipe line that is full of fluid or gas that you want to seal.
if it is for a piped system then you can use PTFE tape or a paste such as Boss white or silicon that has an anti mould agent in it.
Without knowing the full application details it is hard to be more help-full to you.
