Previous in Forum: Sealing Screw Threads   Next in Forum: VW Polo TDi - Warning Lights
1998 Chevy s-10 With a 4l460e Transmission
07/13/2010 5:18 AM
HI everyone, i have a 1998 chevy s-10 with atransmission problem, i put a transmission in my truck that had been in storage for a while it worked good when it was in another truck but now that it is in mine low gear dosent work, all of the other gears work fine, we put it up on blocks with the wheels off the ground and low gear would kick in but soon as we put it back on the ground it wouldnt go into low gear,can anyone help with this problem, the transmission is a 4l460e, in which i was told that it is very complicated transmission to work on.
Re: 1998 chevy s-10 with a 4l460e transmission
07/13/2010 5:24 AM
Maybe you should talk to this person. 1995 Chevy S-10
Re: 1998 Chevy s-10 With a 4l460e Transmission
07/14/2010 2:23 AM
Look here:
http://www.familycar.com/transmission.htm
ad here:
http://www.autoshop101.com/forms/AT21.pdf
When transmissions sit empty, spool valves in the valve body can rust and stick. When transmissions sit full of dirty fluid the dirt falls out of suspension and can clog passages in the valve body.
Since low gear works with the drive wheels off the ground then there is low apply pressure to one of the clutches holding one of the two planetary members stationary. If you refer to the power flow diagram you'll be able to determine which clutch is applied in low gear that is different from the combination in second gear.
If you then drop the trans pan and get a fluid flow diagram from GM, then with a rubber tip air nozzle you can pressurize each clutch pack and brake an listen for leaks. If each component thunks authoritatively and no leaks are heard then the problem is a sticking valve, check ball, weak or broken spring in the valve body.
Bob
07/14/2010 3:06 AM
thank you for your info on my transmission, it greatly appriciated, ty
Register to Reply 3 comments
lyn (1); richardaw1011 (1); wrench (1)
