Previous in Forum: ASME B16.20 Spiral Wound Gasket Centering Ring Material Abbreviation   Next in Forum: AHU CFM & Tonnage Calculation
Pneumatic Test Pressure
07/12/2010 12:06 PM
I have seen in many company standards says Pipe pneumatic test shall be carried out for the test pressure of 1.1 times design pressure or 700 kpa(100 PSI), whichever is minimum. I don't know the basis for 700 Kpa (100PSI).
Could you please explain me the fact behind this.
Regards,
K.Uthayasankar.
Re: Pneumatic test pressure
07/12/2010 12:28 PM
Is that after a hydraulic test to a higher pressure?
[The original poster's question might make the more sensitive reader nervous, because 5psi of air is very dangerous if it is propelling a large manhole cover in the direction of an unsuspecting Engineer....]
Good Answers: 38
Re: Pneumatic Test Pressure
07/12/2010 8:14 PM
Common sense.....
Please specify which company standards that you seem to recall.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
07/12/2010 10:18 PM
Never heard of the requirements that you listed. However it is common to test at 1.5 the system/equipment rating.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
07/13/2010 3:05 AM
hi, you have listed that the pneumatic test shall be carried out of 1.1 times design pressure. This can be done in everywhere but regarding 700kpa i haven't ever come across. you have mentioned that whichever is minimum it can be done. So i think due to inherent dangers associated with pneumatic test the pressure of the air/gas should be minimum. Thats why that company might be used of 700kpa.
Good Answers: 27
07/13/2010 7:04 AM
Tend to agree with Natarajan.
ASME-section VIII - Pressure vessels uses 1.1 times MAWP (or design pressure I think) for pneumatic testing. This is a requirement if used in place of hydro test.
It seems to me that the 100psi limit is an in-company rule for "leak testing", not pressure testing.
Personally I avoid pneumatic pressure testing if at all possible.
I have no special talent. I am only passionately curious. Albert E
Good Answers: 38
07/14/2010 2:13 PM
See: www.lngpedia.com/blast-kills-worker-at-shanghai-lng-project/
I think that this explains everything you need to know
Kaisan (1); miketheboilerguy (1); MJCronin (2); Natarajan (1); PWSlack (1)
