Previous in Forum: Duct Forming   Next in Forum: Seam Welding vs. Seamless Welding
Limitation For Maximum Of Root Welding Reinforcement (After Welding)
07/12/2010 11:23 PM
dear all,
After flange neck to pipe welding with tig(gtaw),root welding reinforcement is +2~3mm then this value(+2~3mm) is accept or reject? if this value is accept or reject , i want to know what ASME code to look for root welding reinforcement's maximum.
Best regards.
Re: Limitation For Maximum Of Root Welding Reinforcement (After Welding)
07/14/2010 4:33 PM
The Max. Weld Reinforcement as per ASME VIII, Div. 1, UW-35(d) :
For groove welds, the thickness of the weld reinforcement on each face shall not exceed the following :
