Previous in Forum: Accuracy of Dry Block Calibrator   Next in Forum: Use of IS Barrier for Intrinsically Safe Instruments
Sensors
07/13/2010 12:13 AM
I am interested in measuring "Eugenol" in a chamber? Can anybody help me with some contact details of sensors to measure eugenol?
Dr.Sridhar
Re: Sensors
07/13/2010 2:25 AM
Measuring what parameter - pressure? Density? Temperature?
Re: Sensors
07/13/2010 6:34 AM
The presence of "Eugenol" inside a chamber. The component is phenolic compound.The compound passes through the chamber as a vapor and escapes out.
The percentage of this component inside the chamber to know its concentration,is what I am interested.
Thanking in advance
Dr.Sridhar
Re: Sensors
07/14/2010 12:30 AM
If eugenol is the only organic substance in the chamber, your job is fairly straightforward. Several sensor types, including metal oxide (Figaro Engineering) or polymer sorption sensors such as SAW based, quartz microbalance, etc. Many instruments advertised as 'toxic gas sensors' will work in your application.
If eugenol is mixed with other compounds, your task becomes immeasurably more complex. Contact me if you need more information.
Good Answers: 146
Re: Sensors
07/14/2010 6:32 PM
This "e-nose" approach using molecular imprinted polymers might be of interest:
http://www.springerlink.com/content/m66p316202757537/
incus opella
Register to Reply 4 comments
artsmith (1); Dr. B.S.Sridhar (1); PWSlack (1); wpenrose (1)
