Previous in Forum: Required Bearing   Next in Forum: Power Plant Operation
Thrust Support In Re-Heater Safety Valve
07/14/2010 12:54 AM
I heard that one of the starting permissive for pressure raising in boiler is checking of thrust support in re-heater safety valve. I want to know why thrust support is needed for placing a safety valve, particularly in a re-heater. Why we are not using this support for safety valves which are used in main stem pipe lines?
Re: Thrust Support In Re-Heater Safety Valve
07/14/2010 2:18 AM
All a matter of strength versus potential thrust forces. Supports are used on pipelines where required.
07/14/2010 2:25 AM
thanks for your answer.thrust support is essential where any thrust load comes into picture.but particularly thrust support is used only in re-heater safety valve support.y we are not using this kind of supports in other safety valves like main steam pipeline safety valve etc...
07/14/2010 4:37 AM
How big is it?
Good Answers: 18
07/15/2010 8:22 AM
You dont say how long the outlet pipe is from the safety valve. The main reason for support is that most outlet pipes ( after the relief) are a horizontal length and an elbow upwards or downwards. When the relief/safety vents, a force is setup in the bend, tending to straighten the bend. This may damage equipment or worse, people. If the horizontal portion is kept very short, basically ±400 mm the straightening forces are much less. Main pipe lines are typically supported at both ends, which provide a flexing/give effect to other safety valves in the lines. (the valve is not rigidly held, as it is directly on the header)
Always learning
Register to Reply 4 comments
Anonymous Poster (1); dhinesht (1); jvrj (1); PWSlack (1)
