Previous in Forum: Control Desk Design   Next in Forum: Smart Transmitter Use as Controller
BTU Value
07/14/2010 6:30 AM
Dear All,
Does the BTU value change after the control Valve or does it remain fixed in the Entire pipeline
As a standard practice for Custody gas meter installation where is it advisable to install Gas Chromotagraph
Regards
Jose John
6
Re: BTU Value
07/14/2010 8:52 AM
Btu values are specific to the particular fuel. Expressed in Btu per unit mass, this does not change with heat or pressure. On the other hand, if it is expressed in Btu per unit volume, then it will change with changes in temperature and pressure.
Reply Good Answer (Score 6)
Re: BTU Value
07/15/2010 8:36 AM
Gas custody metering would be at standard conditions.
Re: BTU Value
03/25/2025 7:21 AM
The original poster withheld the flowrate, temperature and pressure, as well as the composition of the <...gas...> in question. It doesn't give much for the forum to go on, does it?
Mikerho (1); PWSlack (1); russ123 (1)
