Previous in Forum: Capacitive Load   Next in Forum: NCT
CT Polarity Test
07/15/2010 1:36 AM
how we check ct polarity
Re: ct test
07/15/2010 2:39 AM
Polarity can be tested using the flick test. Connect an analog ammeter (hand‐held
multi‐meter) to the secondary terminals of the CT, meter positive to X1 and
negative to X2. Using a suitable low‐voltage battery, connect the negative terminal
to H2 of the CT. While watching the analog ammeter, apply a current pulse to the
CT by connecting and disconnecting the battery positive to H1 of the CT. If the
polarity is correct, the meter needle gives a positive flick on closing and a negative
flick on breaking the circuit
Good Answers: 244
Re: ct test
07/15/2010 9:00 PM
See also this thread http://cr4.globalspec.com/thread/33197
- MS
