Previous in Forum: Quick Electromagnet Question   Next in Forum: what are the standard test of a CT?
9 comments
How to test the polarity of a CT
02/10/2009 10:01 PM
Please help me. I am a new engineer. My boss ask me in how to test the polarity of a CT? and what will be test equipment will be used
Good Answers: 244
Re: How to test the polarity of a CT
02/10/2009 10:15 PM
All you need a 1.5V dry cell battery, a multimeter and few pieces of wire. Connect the multimeter in CT secondary to measure DC current. Quickly connect and disconnect the battery in the primary. You can now find the primary terminal entering the current (connected to the positive terminal of the battery) and secondary terminal exiting the current (from DC ammeter polarity). It is so simple, quick and interesting.
- MS
02/10/2009 10:49 PM
thank you so much..may i know what are the other standards test of a CT?
Good Answers: 103
02/11/2009 2:00 AM
Very interesting concept. Using a square pulse.
Own ?
OP: For CT testing please refer to standards IEC 60044 for the CT it is part-1
If you are in the ANSI zone it is ANSI C57 series (i think C57.13)
Check these standards.
02/11/2009 2:28 AM
thanks
Good Answers: 103
02/11/2009 8:47 AM
who MS or A ?
07/31/2009 9:31 AM
good answer
01/12/2010 12:51 PM
make sure that you use anlog meter for this test
Thanks
Arvind
08/02/2010 6:04 PM
Hi,
Could you explain little more? Because transformer cannot sense DC current due to its inductive property(If it is CT or power transformer).
XL = 2 *pi * f * L
XL - Inductive Reactance (Which opposes current flow like resistance)
pi - constant (3.14)
F - Frequence (In case of DC this equals zero)
L - Inductance
Therefore XL = 0 which means short circuit
Thanks & Regards
Sikander
Design Engineer - HV control & Protection
CR4 Admin – E-mail Address Removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
01/22/2011 11:42 AM
the needle of DC ammeter will move clock wise, the clock wise movement of needle shows correct polarity....
Register to Reply 9 comments
Anonymous Poster (5); atchet (1); msamad (1); sb (2)
