Previous in Forum: Welded Base Plate   Next in Forum: GD2 Value of a Centrifugal Blower Rotor
Mechanical Fault with Toyota Avensis
07/15/2010 6:08 AM
Fellow CR4 members,
About four months ago, I discovered that my car was not firing well. I met my local mechanic who diagnosed faults with two valves and burnt top gaskets. Valves were grinded, top gaskets changed and general servicing carried out including the nozzles.
After all these, the car cannot go beyond 120 km/hr. Any attempt to go beyond that speed range, leads to some kind of recession or drawback in the movement of the car. Recently I had to change the plugs and the fuel filter cleaned, but the fault still persists.
Other Information: 1.8 engine capacity and 2004 model
Can you please help me diagnose the fault with the car?
Emma.
Good Answers: 60
Re: Mechanical Fault with Toyota Avensis
07/15/2010 11:01 AM
in case i am wrong you can use this link
http://www.toyotaownersclub.com/forums/lofiversion/index.php/t16378.html
check the compressions of the cylinders.
remove the exhaust befor the cat and see if problem is still there, reason if valves are burnt there would be unburnt fuel going past valves and unburnt fuel causes lots of damage to cats, and they block up giving a rise in back presure in the exhaust noticable by lack of top end power Its bad when your cats blocked
07/16/2010 3:22 AM
I cannot imagine why a mechanic would dismantle an engine and only grind two valves, totally crazy and a waste of time and money.
Your mechanic is not working well for you, or you are over controlling him.....
Remember, some people "save money no matter what it costs!"
Logically if two valves need this sort of attention, then the others are not far behind, so the whole cylinder head should have been serviced fully.
1) Check block for flatness, especially in the area of the damaged gasket.
2) Light skim of the head to assure flatness. I did this once and found that in all I had to take off 1mm to get the head flat agin. Mitsubishi Diesel head......
3) All valves reground and lapped in.
4) Check for broken/damaged/loss of tension valve springs, maybe replace all.....
5) Re-build of head......all clearances of all valves checked, though I suspect it has oil lifters, I have not got much personal experience of these, but possibly some are worn?
07/16/2010 4:53 AM
Check the exhaust sensor, may have become contaminated prior to head works by non combusted fuel. Sensor failure would put the engine management system into fault mode
Andy Germany (1); Anonymous Poster (1); peterg7lyq (1)
